The cable to the sliding door on my Sharan 7N from 2014 has jumped off the little tap and it cannot be put back on. The cable has been pulled almost all the way in, and the door „locks“ so it cannot go to where the cable can reach.
I read the factory repair manual that it is possible to put the cable motor control unit in „customer service mode“ and as it states (In customer service mode, the drive motor is uncoupled from the drive). This sounds quite good.
Can this be done by VCDS or do you need a factory tester?
This is the description:
Customer service mode, right sliding door - J731
Body
General body repairs (Rep. Gr. 01; 50…77)
01 - Systems capable of self-diagnosis
BF - right sliding door - J731
BF - right sliding door, functions
BF - Customer service mode (Rep.Gr. 58)
Thanks,
Jakob
