Zero drive after front Shock replacement
Hello,
Ive just replaced a front RH shock absorber on a VW Sharan 2 (manual) and when I put it into gear after putting everything back I get no drive at all in forward or reverse. Cant think what I’ve done wrong here, I replaced the other side (left side) a week ago with no issues. Any ideas?
Just remembered, I had some trouble lining up the 3 screws from the ball-joint into the wishbone as the upright was too far out. Is there a second spline at the differential end of the drive shaft? and if that was not engaged would it cause no drive at both wheels.
An update, which may be useful to others. I had no drive because the inner CV joint came out of engagement. When I investigated I found that the CV joint cage had broken up which allowed the shaft to disengage from the gearbox. Mine is the 6-ball type of CV joint, not the trilobe on some models. Normally this version should not pull apart unless the circlip is removed or it is badly worn or damaged.
Hi!
Thanks for the update.
Have you taken some fotos of the broken part which you could share here?
Was there no strange noise created by the broken joint cage?
Why did it brake during shock replacement? I would expect it to brake while driving and having a high torque on the joint. :man_shrugging:
Car came from Scotland originally, they have very bad roads (like Ireland). The reason I changed the shock absorber was because the spring broke, I’m an engineer and can see that the spring broke from fatigue over a long time. The cracked ball-cage could still be retained ok inside of the CV body but when I pulled to get shock absorber free from lower mounting the inner CV joint came apart. Disconnecting the assembly from the lower arm would have given space for the shaft to come out of the CV joint.
